Jelle_ZX7R
- 20 dec 2006
- 1.501
- 0
Hoi,
ik bied mijn ongebruikte Dynatek 2000 ontsteking aan. Nieuw in doos.
Reden van verkoop. Ik heb hem al een aantal maanden en ga hem niet gebruiken, vandaar de verkoop. Het gaat om de DDK2-7 Goedkoopste op ebay is 230 euro.
doe maar een leuk bod:
Bekijk Mijn Motor-ForumBekijk onderwerpenBerichten:1.375Reg. datum:20 dec. 2006even wat propaganda:
The Dyna 2000 for four cylinder engines represents a breakthrough in motorcycle ignition flexibility. The Dyna 2000 system consists of a state-of-the-art microprocessor controlled ignition module along with an adjustable Dyna dual sensor crank trigger. For the first time you can actually set the ignition timing to what you want to maximize engine performance. A number of different advance curve modes and a broad range rev limiter let you tailor the ignition to your needs. Dynatek has added the ability to custom program the Dyna 2000 Sportbike ignition via a personal computer. Like our programmable Harley-Davidson and Dyna FS ignitions the Dyna 2000 can be programmed with a custom advance curve, retard mode curve and RPM limit using the optional accessory curve maker kit. There are also 2 user programmable RPM outputs that can be used to activate a shift lightor other RPM activated device.
van de site: DDK2-7 1993-1997 Kawasaki ZX 9R $399.99
