Motor trekt met koppeling in
latm
7 mrt 2007
1.101
1
Al een tijd in bezit van een sv650 en onlangs viel het me op dat de motor de neiging had bij stoplichten in de eerste versnelling met de koppeling ingetrokken naar voren wil kruipen. Wanneer ik meer gas geef gaat hij ook harder naar voren.
Nu vond ik op internet dat ik dan de koppeling moest afstellen en dan met name het mechanisme bij het voortandwiel. Hiervoor vond ik onderstaande beschrijving:
FAQ: How do I adust my clutch? AndyAuger's Clutch Mantra - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Courtesy of AndyAuger.
Andy Auger's Clutch Mantra
Here's the solution to most clutch and shifting issues. This includes hard shifting, slipping clutch, frequent missed shifts, etc. It's always a good idea to have a shop manual handy just in case.
1. Adjust the release mechanism.
- Remove the front sprocket cover.
- Loosen the clutch cable using one or both cable adjusters so you have lots of slack.
- Loosen the jam nut on the lever arm that the clutch attaches to under the front sprocket cover. Use a box end wrench.
- Leave the wrench on the jam nut and turn the screw (actually the release rod) counterclockwise until you are sure it no longer is in contact with the push rod (tip: use a screwdriver with a tip the same width as the screw to avoid conflict with the jam nut). You need a little clearance between the release rod and the pushrod. Now gently turn the rod clockwise until you feel light pressure. Now turn the rod counterclockwise 1/4 turn. Leave the screwdriver in place to keep the rod from turning and tighten the jam nut. This sets the end clearance of the release rod.
2. Adjust cable slack.
- Screw the cable adjuster at the lever in pretty much all the way. Back the adjuster at the engine case out until you have about 1/2" free play measured at the end of the lever. If you can't get down to 1/2" slack using the engine case adjuster alone, use the adjuster at the lever also.
This puts the release mechanism and the clutch lever where they're supposed to be for best function. Consider lubricating the cable while you're fooling around with it. It's easy to remove it from the lever when the adjusters are all the way in.
3. Change the oil.
If your oil is old or has a lot of mileage on it (6 months or 3,000 miles) change it. Consider changing the filter, too. Don't overfill. (Note that if you always ride an hour or more every time you get on the bike the oil can go more than 3,000 miles, but if you don't ride much don't go more than 6 months regardless of mileage).
4. Check the oil level.
The proper way to check the oil level is to put in the appropriate amount, start the engine and let it run about 30 seconds, stop the engine and wait about two minutes. Now stand the bike up vertically and look at the level in the sight glass. The oil level should be BETWEEN the marks. Overfilling will make the clutch drag and cause hard shifting.
5. Clean, lubricate and adjust external linkage.
Take a look at the external shift linkage. Both ends of the tie bar should be clean and lubricated. The best way to lubricate is to pack the joints with something like Lubriplate (white grease) or similar product. Silicon greases (like Dow-Corning 111 compound) work well also. Plain old oil will work, but not last as long.
This next part isn't as common a problem, but it is a fine point that can cause trouble.
Look at the relative position of the "lever arms" at the foot lever and the transmission. They should be as close to parallel as possible. Sometimes when you adjust for good foot position the two "lever arms" are at a pretty steep angle relative to one another. Sometimes you have to remove the lever from the transmission and rotate it a tooth or two from stock position.
If all this doesn't work then the problem could be either in the clutch itself or in the internal mechanism. Good luck.
Nu heb ik al geprobeerd hem te stellen volgens stap 1 maar dat gaf nog niet veel resultaat. Motor achter opgebokt. Mechanisme versteld maar het achterwiel blijft draaien met de koppeling ingetrokken. Nu kan dit deels komen door een koude motor en plakkende platen. Maar het kost redelijk wat kracht om het wiel met de achterrem te stoppen.
Kan iemand me vertellen wat ik nu precies aan het verstellen ben? Zoals ik het begrijp bepaald de schroef hoe snel de koppeling aangrijpt. Staat hij volledig ingedraaid dan drukt hij altijd de koppelingsstang in en zou het achterwiel bijna niet moeten draaien. Staat hij te te los dan grijpt hij laat aan waardoor je niet volledig ontkoppeld.
Is bovenstaande juist?
Als de platen versleten zijn dan zou vooral het slippen van de koppeling bij hoge toeren het probleem moeten zijn lijkt me.
Ligt er natuurlijk aan hoe de berijder met z'n motor omgaat. Bij een rustig rijgedrag kun je nog heel erg lang rijden met een versleten koppeling hoor.
Het meest voor de hand liggende is inderdaad dat de beklede platen glad/gladder/versleten zijn en aan de stalen platen blijven kleven.
Het zal dus op een inspectie/vernieuwing uitdraaien.
Je gebruikt neem ik aan wel de juiste olie?
De werkende slag op het handle is voldoende? Dus de koppeling word goed bediend, en niet maar net net ontkoppeld?.
Als de koppeling al wat ouder is en/of veel te verduren heeft gehad, zijn de stalen tussenplaten niet meer recht. Dit uit zich vaak in het niet volledig ontkoppelen, ongeacht hoe ver je de hende intrekt en afstelt. Enige oplossing is de platenset vervangen, maar of dit een optie is hangt imo af van de kilometerstand.
Kabelspeling checken en verse olie, als dat niet helpt dan zou ik de koppeling vervangen.
Nog even verder gezocht maar een versleten koppeling zou ik moeten merken dat hij slipt bij hard optrekken. Dit heb ik gisteren nog gedaan om te testen en ik merkte niets van een slippende koppeling.
Ik zoek het probleem dus nog in het mechanisme.
Als je het mechanisme maximaal hebt bijgesteld, en het probleem blijft, dan zit het niet in het mechanisme.
De vraag is of je het goed hebt gedaan, en of er misschien met het mechanisme zelf iets niet goed is.
Anders blijft alleen de koppeling zelf over, en dus openmaken en inspecteren. Kan de korf zijn, de tussenplaten, zeg het maar.
aan je stuur aan de kabel trekken weg van het hendel. ondertussen je hendel even intrekken (en weer lossen) totdat de kabel tot tegen de houder wordt getrokken. zo meet je de vrije speling op de kabel. je zou de kabel zo 1mm over en weer moeten kunnen trekken. is dat veel meer, bijregelen met die vijs aan je hendel waar de kabel door loopt tot je maar 1 mm meer over hebt en opnieuw testen of je motor nog vooruit wil met ingetrokken koppeling.
