Welkom bij KTM 690 SMC(-R) deel 8
ENGINE
DESIGN
1-cylinder, 4-stroke engine
DISPLACEMENT
690 cm³
BORE
102 mm
STROKE
84.5 mm
POWER IN KW
49 kW
STARTER
Electric starter
LUBRICATION
Forced oil lubrication with 2 oil pumps
TRANSMISSION
6-speed
PRIMARY DRIVE
36:79
SECONDARY GEAR RATIO
16:42
COOLING
Liquid cooled
CLUTCH
APTC(TM) slipper clutch, hydraulically actuated
EMS
Keihin EMS with RBW, twin ignition
CHASSIS
FRAME DESIGN
Chromium-Molybdenum steel trellis frame, powder coated
FRONT SUSPENSION
WP USD Ø 48 mm
REAR SUSPENSION
WP shock absorber with Pro-Lever linkage
SUSPENSION TRAVEL (FRONT)
215 mm
SUSPENSION TRAVEL (REAR)
250 mm
FRONT BRAKE
Brembo four-piston radial fixed calliper, brake disc
REAR BRAKE
Brembo single-piston floating calliper, brake disc
FRONT BRAKE DISC DIAMETER
320 mm
REAR BRAKE DISC DIAMETER
240 mm
ABS
Bosch 9M+ two-channel ABS (disengageable, optional Supermoto mode)
CHAIN
X-Ring 5/8 x 1/4"
STEERING HEAD ANGLE
63 °
WHEELBASE
1480 ± 15 mm
GROUND CLEARANCE
270 mm
SEAT HEIGHT
890 mm
TANK CAPACITY (APPROX.)
12 l
DRY WEIGHT
141 kg
VOORGAANDE TOPICS:
# KTM 690 smc 2008 #
#KTM 690 SMC# deel 2
KTM SMC 690 Deel 3 Braaaaap!
K™ 690 Sm© deel 4, hij gaat hard!
K™ 690 Sm© deel 5 onroad/offroad...broaapen!
KTM 690 SMC-R Deel 6 Broaaapen met die zooi!
KTM 690 SMC-R Deel 7 Broaaaper die broaaap!
Topic Members
*Fuse*
Aoks
broaap
else
hdegroot
Isdatzo
joeyverveer
Josss
look
LuukR
MajestiC
maR1tijnCR
PeterVB
Ranx
RB-
RedHenk
RG690smc-R
RR-Neliz
sjorrit
smpowah
SPutnick
tetsu
XR 600SM
