Oerknal
- 17 dec 2008
- 2.115
- 1
Vergeet Powercommanders! Flash je ECU nu met deze set en haal het onderste uit de kan:
Bench ECU Flashing Kit Includes:
-FTdataLink ECU Interface USB Cable
-Bench Flashing Harness to flash your ECU outside of the bike
-Power Supply for Bench flashing
This Interface allows you to easily adjust the following!
Remove ECU Restrictions
Engine Braking adjustments
High Load Fuel Maps (with PC3 and PC5 map importing)
Low Load (cruising) Fuel Maps
Fuel Injector Proportioning
Ignition Timing
Immobilizer Function
Cooling Fan Temps
Rev-Limiter Control
Remove Top Speed Limiter
ECU Based Quick-shifting
Speedometer calibrations and new features are added regularly
*Let op: er dient nog wel een ECU Single/Multi License bijgekocht te worden.
Ignition Timing
Cooling Fan Temps
Rev-Limiter Control
