I use polini hi-speed, not with the original 6.5gr roller weigts but 7.0gr! I made a huge amount of tests in roller weigts and different clutch sping settings. The 20%+ techpulley spring, and Hit clutch!
I thought polini variator was great at the begining, but now it is much better!
If your middle man gets a better price, can you tell him to buy a second one for me?
nee ik heb de polini druk veer en deze is 20% geloof ik zwaarder.
maar op de een of andere manier pakt hij hem nu ineens bij het minste gering beweging van het gas.
hij maakt dus niet meer eerst toeren en dan beweging.
maar zodra je nu de toerennaald ziet bewegen komt de scoot ook gelijk in beweging.
dat deed hij met de originele druk veer dus niet.
door het betere oppakken is dan ook weer de top snelheid iets omhoog gegaan.
Products Information:
aRacer SpeedTek RC1 Complete computer
RC1 Complete computer is the new generation ECU with ASSCT technology (aRacer SpeedTek Software Core
Technogy). It is designed for new EFI motorcycle applications. aRacer simplify the complex engine model formula with intuition calibration tool. User can use the easy GUI (SpeedTuning calibration tool) to calibrate fuel & ignition MAP quickly and simply. All engine model use stock Manifold Air Pressure Sensor (MAP) & Throttle Position Sensor (TPS) & Inlet Air Sensor (IAT) to be the base to calculate the inlet air amount. It helps the EFI engine can run stable and reliable in all environment. RC1 is not only suitable for race circuit and also good for daily riding (depend on country regulation). RC1 is the powerful ECU for EFI racing engine applications. You can calibrate the parameters easily to meet racing engine parts, such as high flow air cleaner, high performance exhaust, high CAM, larger displacement, high engine speed needed etc.. aRacer SpeedTek Tech center also provides the stock engine MAP file and various upgrade engine MAP file in cloud for download. User can enjoy
the FEI power easily!!
Ik dacht dat de Keihin ecu al redelijk gemakkelijk volledig te herprogrammeren was .. (volgens een tuningcenter hier in de buurt, geen merkverdeler alleen tunig daar) Maar ik weet het niet.
Die BMW gaat als eens raket, de andere clutch t.b.v. verbeterde in-board CVT cooling is alleen voor freaks die het beter/mooier willen laten lopen, voor de easy-rider is standaard waarschijnlijk goed genoeg?Bmw c650 sport
+ zithouding,vermogen, en look
- prijs, gewicht, problemen clutch?
Ik vindt zelf de Honda 750 ook wel een super ding, niet op gereden maar vermoed dat het wel lekker door kachelt, en dat hij de enige is die de BMW gewoon easy kan bijbenen.Intrgra
+ super motor en dct, prijs, look, verbruik
- zithouding( zit niet graag te recht en te laag met men achterste, geeft teveel rugproblemen, dus liever wat voorover en benen zo laag mogelijk)
Ik heb op de 530 gereden, die had de zelfde beenruimte als de BMW.T-max
+ look, zit goed
- prijs, onderhoud, vermogen, overgewaardeerd
