- Onderwerp starter
- #1.251
WTF, vandaag doekje er af, starten, no problem....
yes, toch problem.... dashboard doet niets, behalve background verlichting.
Iemand idee??
Bij mij was dit een kapot dashboard, heb het niet meer aan de praat gekregen.
Je zou dit kunnen proberen:
If it’s just the speedo unit, from Soft 32 Dat 101 thread - check for broken red/white wire at 12 pole connector to bottom lhs (sitting on the bike) behind headlamp - from the wiring diagram, this appears to be the power source (excluding backlight) for the speedo unit - manual is wrong/inconsistent re description for this connector and the one above as the bottom one is definitely for the front wiring loom including the speedo unit.
superduke forum • View topic - 990 instrument cluster Fail
