NoExpert
Decided I'd finally post the little bit of tweaking I've done to my R1 and give some of the back story.
I totaled my 2014 R6 12.01.2015, a little over 6 months after buying it.
While at the shop discussing the damages I noticed their last two 2014 R1's were on clearance at pretty good prices. After a night to think about it I put a deposit on one the next morning and I brought it home about a week later on 04.02.2015.
I pulled the side reflectors and dealer plate off as well as installed the Woodcraft swing arm slider spools and Antigravity battery from the R6 the day I brought it home. I also flipped the shift linkage for GP style shifting since I prefer this.
Here's what's been done so far as well as what's in the plans. This list will be updated as parts get added/changed.
Totally stock a few minutes after bringing it home from the dealership 04.02.2015
ON THE BIKE
AntiGravity LiFePo4 battery 04.02.2015
Woodcraft swing arm slider spools 04.02.2015
Renthal clip ons 07.02.2015
Woodcraft weighted bar end sliders 07.02.2015
Removed CA emissions charcoal canister 14.02.2015
Yoshimura fender eliminator 17.02.2015
FlashTune ECU bike side wire harness/flashed ECU 26.02.2015
Valter Moto oil cap 11.03.2015
Traxxion Dynamics preload adjuster knobs 12.03.2015
TWM SC fuel cap 12.03.2015
GYTR rear seat cowl 13.03.2015
NoMar rear peg removal plates/reservoir bracket 13.03.2015
Leo Vince SBK Evo II full system (SS/CF) 13.03.2015
Graves smog block off plates (removed AIS system) 13.03.2015
Sprint air filter 13.03.2015
(no photo)
Modified RN23 airbox to RN22 style 13.03.2015
Tygon 8mm tube between front m/c and reservoir 21.03.2015
(no photo)
TST Industries electronic flasher relay 21.03.2015
(no photo)
T-Rex adjustable rear linkage arm (+5.25 mm lift) 21.03.2015
Traxxion Dynamics custom rear spring spacer 21.03.2015
(no photo)
Hypercoils linear rear spring 21.03.2015
(no photo)
90° valve stems 28.03.2015
Traxxion Dynamics linear front fork springs 03.04.2015
(no photo)
Suspension tuned by SST 03.04.2015
(no photo)
Traxxion Dynamics 2mm shock shim (+4 mm lift) 20.06.2015
GYTR smoke raised windscreen 23.07.2015
Optimate LiFePo4 battery tester/connector 24.07.2015
Renthal dual compound Kevlar grips 24.07.2015
Traf-X X-Light 02 LED turn signals (rear) 30.07.2015
Pirelli Angel GT tires (installed at 7.000 km) 04.08.2015
Graves mechanical cam chain tensioner (CCT) 04.08.2015
Cox radiator guard 05.08.2015
Stahlbus oil drain valve 22.08.2015
(no photo)
WD flush mount LED front turn signals 29.08.2015
StompGrip clear tank grip 12.09.2015
RoadLok disc brake lock 12.09.2015
Custom LED Blaster-X taillight 26.09.2015
Custom LED Blaster-X control switch 26.09.2015
(no photo)
Woodcraft frame slider pucks (short) and mounts 26.09.2015
Woodcraft front axle sliders 29.09.2015
Osram Super Bright 65w headlight bulbs 02.10.2015
(no photo)
RAM X-Mount 25.10.2015
04-08 clutch kit (friction plate, clutch boss spring, seat plate) 23.12.2015
(no photo)
Barnett heavy duty clutch springs (installed 3 of 6) 23.12.2015
(no photo)
2015 R1M sprocket cover 08.01.2016
Knock off black levers 14.01.2016
Fuel line mod 14.02.2016
(no photo)
Samco silicone hoses in red 29.04.2016
Woodcraft case covers with stainless steel skid plates 29.04.2016
Custom aluminum radiator hose to go past header 29.04.2016
HealTech iQSE-1 quickshifter 02.06.2016
Robby Moto quick action throttle (pending due to broken cable)
Domino Parco grips 02.06.2016
Changed spark plugs 02.06.2016
GARAGE TOOLS
Woodcraft race rear stand (for spools)
Woodcraft stem lift front stand
Optimate TM-291 LiFePo4 battery charger
WAITING TO BE INSTALLED/ON THE WAY
Brembo rear brake light pressure switch
PLAN TO ORDER
Woolich Race Tuned flash interface/data logger
Fren Tubo Carbotech brake lines
MMR ultra lightweight rear rotor
Galespeed VRC front master cylinder
Galespeed clutch perch
LighTech chain tighteners in red
Hopefully it's not too terribly boring. Currently I am running a FlashTune ECU setup but, later I may change to a Woolich Racing Tuned log box setup. Still deciding if I'll import my bike when we move or if I'll buy a new one over there.
ON THE BIKE
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
(no photo)
GARAGE TOOLS
PLAN TO ORDER
