ZGAN 380/220 v Vraagprijs voor deze compressor met gegarandeerd weinig draaiuren !
is 475 € ..nu 375€
Product DescriptionAtlas Copco LFx 0.7-10 TM50 Compact, Silent Tank Mounted air compressor from the Atlas Copco factory in Italy.
Silent Air Compressor Piston Atlas Copco LFx 0.7-10 TM50This range of small capacity, oil free compressors are built for high performance and a long lifetime. Suitable for laboratory, factory, small food operations where Oil Free compressed air is required.
Certified ISO 8573-1 Class 0 by the TUV institute: guaranteed 100% oil free operation.
Virtually maintenance free (no oil change required)
Clean quiet operation (62 to 67 dB(A) standard)
Compact design for trouble free installation
LFx 0.7-10 TM50
•Air Receiver 50 litres, epoxy lined
•Working Pressure 10bar / 145psi
•FAD 1.02 L/s / 2.16cfm
•Motor 0.55kw / 0.7hp
•Dimensions 828 x 355 x 891
•Weight 49kg
•Noise level 65-67 dB(A)
•Made in Italy
https://www.google.nl/url?sa=t&rct=...lb.pdf&usg=AFQjCNHA_IE5s46AHZpj8V4rOBP9VjfLbA
is 475 € ..nu 375€
LFx 0.7-10 TM50
•Weight 49kg
•Made in Italy
