Danmoto demper
Matt Mobylette
26 nov 2007
335
Nette carbon Danmoto demper!
Zit nu op een CBR600f4!
Demper zelf is universeel toepasbaar! Aansluiting naar linkpijp = 51mm! Buitendiamer: 90mm en lengtr is 300mm!
Geluid is waanzinnig gaaf maar erg luid! Evt (in) ruilen tegen een andere demper met E keurmerk!
Prijs voor de losse demper inc. Db killer = 100,- €
Groetjes,
Marc
Kan je mij vertellen wat de BINNEN diameter van de demper zelf is? Daar waar hij aansluit op het stukje pijp (bij de veertjes).
Volgens mij is dit 51mm! Zal dit morgen even checken!
Er zit trouwens een DB-killer in!
Heb je het inmiddels twee en een halve dag later al gechecked? :P
ja, is 'look', aangezien deze van Danmoto regelmatig verbranden.
-The Danmoto Carbon GP mufflers are race inspired exhausts, made with the same technique as the real MotoGP exhausts.
It has a deep, throaty sound you will enjoy.
-Every exhaust is completely hand crafted by one of our skilled technicians.
-The sleeve is made from 12K carbon fiber with a high gloss finish.
It's not a thin layer of Carbon look-a-like on a metal tube, like some other manufacturers use it.
-Mid pipe, end caps and inner construction of the exhaust are completely SS304 Stainless steel.
-All welds have been done by a TIG welding expert.
-This exhausts offers massive weight savings over the original exhaust.
-One muffler weighs less than 1kg; the whole setup including mid pipe and all mounting hardware weighs in total just about 4kg.
-The mufflers have 300mm sleeve lenght and 90mm OD.
-Every Danmoto Exhaust is developed specially for each bike.
Installation of this exhaust requires no fuelling adjustments/tuning.
-It gives an instant power increase over stock of average 4%.
With adjusted fuelling even more is possible.
-The exhausts are sold as open “Race Version” without Baffle.
This does not mean these are just empty pipes which sound like a tin can.
-Inside the exhaust is a bike specific core with a packing of long lasting fiber material, specially composed for this application.
An additional baffle is available, which reduces the noise level but keeps the nice tone and rumble.
Verbranden kan ook andere oorzaken hebben. Slechte hars die niet hittebestendig is, in combinatie met weinig demperwol of demperwol die snel wegfikt. Teveel hitte bij niet hittebestendige hars, et voila.
Voor de advertentie neukertjes, als je hem nieuw wilt bestellen heb je altijd kans dat hij bij de douane terecht komt.
Wat is de totale lengte van de demper?
Iedereen bedankt voor de aanvullingen! *O*
Voor de mierenneukers onder ons is de begin post aangepast!
