Hoi.
Iemand die deze mod al heeft gedaan bij een duc monster?
Wat bedoelen ze met een grinder?
Ik neem aan een slijptol?
Maar hoe kom je daar nou tussen met een slijptol
Take your die grinder and cut out the little disc surrounding the pipe. Once that falls out,
begin to cut the pipe back into the muffler, removing the baffles and packing as it comes
loose. You only need to go in about 3 inches or so for the full effect. Also, keep in mind
that this isn't a performance mod, only a sound mod. My friend did the die grinder
method, but beforehand he put my already modified mufflers on his bike to compare
them with stock. He noticed barely any difference- maybe a teeny bit less torque. Then
again, the sound is WELL worth it. It is intoxicating to say the least, and totally
transforms the whole driving experience. The pic below shows how far in the mufflers are
cored (stuff removed/cut back to). To the best of my knowledge, the packing is still down
below the line. But, my friend's packing is definitely still below the line the way he did it,
and it has the same sound. You really don't need to pull it all out.
