Kirishima
Heeft uitlaatband ook een functie, behalve dat het 'ruiger' uitziet?
Jaap
Ja, het zou moeten zorgen voor een beter presterende motor Zelf merk ik wel dat de motor wat gretiger/agressiever/directer is geworden.
Een uitlegje in het Engels:
Why Use Exhaust Wraps?
Using exhaust wrap can increase the performance of your engine.
Whether you are a racing specialist or simply an aficionado, our exhaust wrap can be useful to you. You will find here an explanation of how an exhaust wrap works and how it helps you increase the performance of your car or motorcycle engine.
The role of an exhaust wrap:
What the exhaust wrap really does is prevent your exhaust tubes to cool down. Therefore an exaust system equiped with the right set of wrap will keep the exhaust gases of your engine at a high temperature. Maintaining the exhaust gases at higher temperatures increases performance on several levels
When traveling at a higher speed in your wrapped exhaust system, the gases will increase the scavenging effect and improve the performance of the intake and exhaust systems as a whole. The exhaust gases are therefore removed faster from your motorcycle or car exhaust system when hot.
Exhaust wrap also improves the performance of the engine in general. Once again, the hot exhaust gases will be expulsed more quickly, leaving room for purer air in the combustion chamber. This will increase the quality of the air-fuel mixture and then improving the engine's performance. Check our wide range of product to find the right exhaust wrap that perfectly fit your needs.
