TeamHeronSuzuki
Two Stroke or No Stroke
- 2 okt 2006
- 37.986
- 19.338
Erg leuke straatracer
Chassis
Spondon TZ250 GP Chassis
TZ bodywork
TZ wheels, brakes, forks, ohlins shock re worked by MCT Suspension
TZ twist grip
Brembo master cylinder front and back and braided lines
CRG Clutch lever/perch
Suzuki RGV500 steering damper
Harris quick release clip ons
Custom GMX Radiator
Translogic Dash
Custom wiring loom by Steve at Motorcycle Wiring Co
Promach custom rearsets
Engine
Yamaha powervalve bottom end with 421cc cheetah cub conversion
Noss machine head
Wicked motorsports +4mm, balanced crank and uprated bearings
Wiseco clutch basket with wicked motorsports straight cut back gear and clutch pusher
38mm mikuni carbs
Wicked motorsport +5 degree intake manifolds matched to modified VForce 3 reed blocks
Harry Barlow designed exhaust
Zeeltronic programmable / switchable ignition
Pro design adjustable timing plate
Nova close ratio gears
TSS uprated gearbox bearings
Power: 102hp (dynapro) at rear wheel
Weight: 127kg with 5 litres of fuel
Graphics by MB Graphics (www.mb-graphics.co.uk)
Chassis
TZ bodywork
TZ twist grip
Custom GMX Radiator
Translogic Dash
Engine
Noss machine head
38mm mikuni carbs
