Hierbij bied ik mijn Honda CBR1000RR SP aan uit maart 2016.
Is helemaal race klaar volgens cup regelementen.
Vraagprijs is €16.500,- ex BTW
De motor heeft momenteel 4500 km gelopen.
Schadevrij en altijd in onderhoud geweest bij Ten Kate Racing Products.
BIKE
HONDA CBR1000RR '16 SP
COOLING
STONE PROTECTOR STD RADIATOR
OIL COOLER KIT CBR1000RR DSBK
TANK CATCH + BRACKET FOR WATER OR FUEL
AIR
K&N AIRFILTER
ELECTRICAL
QUICK SHIFTER HM/TKR CBR1000RR (PLUS) HS
STAY, HM/TKR QUICKSHIFTER
HRC ELECTRICAL KIT
SUSPENSION
TKRP MODIFICATION SP FRONTFORK OHLINS
OHLINS TTX36 SHOCK
BRACKET PA OHLINS TTX
OHLINS STEERING DAMPER KIT (68MM STROKE)
BRACKET,STEERING DAMPER
CLAMP STEERINGDAMPER 50MM
EXHAUST
EXHAUST SLIP-ON (SILENCE) CBR1000RR STEEL
FRONT PIPES ARROW STAINL.TITAN
CLUTCH
CLUTCHLEVER FOLDING MODEL LIGHTECH
FUEL
HOSE SET, TANKBREATHER
FUEL TANK FOAM FOR RACE FUELTANK
FUELCAP TKRP HONDA BLACK
STEERING
SLIDE BLOCKS CLIP-ON TKRP (CRASH DAMAGE PROTECT.)
STEERINGLOCK SET (ONLY BOLT SET)
PROGUARD SYSTEM FOR BRAKE
PROGUARD MOUNTING ADAPTOR
THROTTLE GRIP COMPL. TKRP VERSION (FOR 1 CABLE)
BRAKE
BRAKELINE FRONT (STAINLESS)
BRAKELINE REAR (STAINLESS)
BRAKEDISC MOTOMASTER FRONT
TKRP TC REAR BRACK DISC WITH TRIGGERING
BANJO BOLT, SET OF 5 (ALUMINIUM)
FRONTBRAKELEVER, (REMOTE) FOLDING & ADJUSTABLE MODEL LIGHTECH
FOOTREST
FOOTREST SET TKRP (BLACK)
GEARSHIFT ARM SET (QSH) (BLACK)
FAIRING (STD BODY WORK STAY AT TKRP)
UPPER PART - (POLYESTER)
LOWER PART - (POLYESTER)
CHAIN COVER - CARBON
FRONT FENDER - (POLYESTER)
QUICK RELEASE TOP FAIRING (SET OF 2)
FAIRINGFASTERNER SET (QUICK TURN) SET OF 6PC
BRACKETSET TANKCOVER
MOUNTING CHASSIS/FAIRING SET SIDE
MOUNTING CHASSIS/FAIRING SET UNDER
SEATFOAM 10MM (SBK PRE SHAPED)
SCREEN RACE AIR (2.5MM)
SCREEN NUTS AND BOLTS (SET OF 7)
AIRDUCT LEFT (POLYESTER)
AIRDUCT RIGHT (POLYESTER)
TANK COVER - (HRC) (POLYESTER)
ENGINE COVER SET GB-RACING
SPROCKET & CHAIN
SPROCKET SET FR.15 & RR.43
CHAIN RACE 520
WHEEL
CHAINADJUSTER RVS
REARWHEEL SPROCKETS FIXATION
TYRE VALVE (90 DEGR.) BLACK 11.4MM
AXLE NUT STAINLESS STEEL
WHEELBUSH SET FRONTWHEEL ALUM.
WHEELBUSH SET REARWHEEL ALUM.
BIKE
COOLING
AIR
K&N AIRFILTER
ELECTRICAL
HRC ELECTRICAL KIT
SUSPENSION
OHLINS TTX36 SHOCK
EXHAUST
CLUTCH
FUEL
STEERING
BRAKE
FOOTREST
SPROCKET & CHAIN
CHAIN RACE 520
WHEEL
CHAINADJUSTER RVS
