Innovate lc-2 wideband sensor
willemsen
21 jun 2010
197
Breda
Wideband sensor om je motor perfect af te stellen. Het betreft een complete set inclusief bosch sensor. Nieuwprijs: 200,- euro(rekening met garantie aanwezig). Ik heb hem afgelopen jaar gekocht om mijn motor af te stellen. Werkt perfect! Nu overbodig aangezien de motor is afgesteld.
Omschrijving:
The evolution of the worlds most popular stand alone digital O² sensor controller, the Innovate Motorsports LC-2 builds upon the legacy of the LC-1 by adding simplicity and leading edge technology. The LC-2 utilizes the only 100% digital wideband air/fuel ratio technology on the market! The LC-2s patented award-winning DirectDigital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LC-2s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition. The LC-2 includes a digital input/output, 2 full-programmable analog outputs, and is ideal for applications such as dynamometers, data acquisition systems, standalone ECUs, and gauges. The LC-2 can also be "daisy-chained" for cost-effective individual cylinder monitoring, and is fully compatible with our Modular Tuning System (MTS). Key features include:
KEY FEATURES
Patented DirectDigital Wideband Technology
Wideband O² Compatible with ALL fuel types
Ability to calibrate O² sensor for maximum accuracy
Integrated dual-color status LED (Green/Red)
Two configurable linear 0-5v analog outputs
Optional sensor cable lengths available: 3ft, 8ft (Included), and 18ft
Positive lock connectors for all connections
Innovate MTS serial in/out
Serial connection to your PC
Real-time display data on screen and/or with powerful LogWorks software
Two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog Output #1 (Yellow) is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR; Analog Output #2 (Brown) 1.1 volt = 14 AFR and .1 volt = 15 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
Compared to the LC-1, here's what the LC-2 adds.
Serial/MTS now have Molex positive lock connectors. No more terminator plug!
Integrated Status LED on the unit itself. Lights up green when everything is operational, but switches to a red light if an error code is present.
Simplified calibration, similar to the MTX-L. No need for a push button.
Simplified wiring- two less wires. One ground wire was eliminated and no LED/push button.
The LC-2's design allows it to be mounted inside the cabin.
Latest implementation of our Direct Digital technology.
Zoekwoorden: tuning lamda zuurstof sensor powercommanderp pcm
willemsen
21 jun 2010
197
Breda
Sensor heeft trouwens maar 300 km op de motor gezeten. 100km voor loggen en naderhand nog om mijn mappings te controleren. Lassok is nog nieuw, aangezien hij al in mijn uitlaat zat.
