T"Genius"J
ENGINE TYPE – FOUR-STROKE, WATER-COOLED, V4
DISPLACEMENT - 990cc
MAX POWER - 220+ ps @ 14,500+ rpm
VALVE TYPE - DOHC FOUR-VALVE
CARBURATION TYPE - FUEL INJECTION
LUBRICATION SYSTEM - WET SUMP
CLUTCH - DRY MULTI PLATES (BACK TORQUE REDUCE TYPE)
TRANSMISSION – SIX-SPEED CONSTANT MESH
FINAL DRIVE - CHAIN
FRAME TYPE - TWIN SPAR ALUMINUM ALLOY FRAME
SUSPENSION FRONT - INVERTED TYPE TELESCOPIC
SUSPENSION REAR - LINK TYPE
TYRES - BRIDGESTONE
WHEEL FRONT - 16.5 inches
WHEEL REAR - 16.
5 inches
BRAKE SYSTEM FRONT - DOUBLE CARBON DISC (CARBON)
BRAKE SYSTEM REAR - SINGLE DISC (STEEL)
OVERALL LENGTH - 2060mm
OVERALL WIDTH - 660mm
OVERALL HEIGHT - 1150mm
WHEELBASE - 1450mm
WEIGHT - 145kg
FUEL TANK - 24L
