Je gebruikt een verouderde webbrowser. Het kan mogelijk deze of andere websites niet correct weergeven. Het is raadzaam om je webbrowser te upgraden of een browser zoals Microsoft Edge of Google Chrome te gebruiken.
De specs (voor de liefhebber):
Model Corsaro 1200
Engine
Engine Moto Morini – Bialbero CorsaCorta
(DOHC - Short Stroke)
Cylinders (no.) 2
Layout 87° V longitudinal
Strokes (no.) 4
Cooling Liquid
Timing system Gear/chain combination
Valves per cylinder 4
Bore x stroke in mm. 107 x 66
Displacement (cc) 1187
Compression ratio 11.8 ± 0.3
Power 103 Kw – 140 HP @ 8500 rpm
Torque 123 Nm – 12.5 Kgm @ 6500 rpm
Fuel injection Magneti Marelli indirect electronic injection with 54 mm
throttle body
Ignition I.A.W. electronic
Starting Electric
Lubrication Forced with trochoidal pump
Gearbox With constant mesh spur gears
Gear ratio 6
In first 13/36
In second 17/32
In third 20/30
In fourth 22/28
In fifth 23/26
In sixth 24/25
Clutch Multiplate in oil bath
Primary Drive Spur gears 55:31
Final Drive Chain
Exhaust With double silencer, 3-way catalytic converter and
oxygen sensor
Polluting emissions Euro 3
Chassis
Frame
ALS450 steel tubular trellis with varying diameters
Wheelbase (mm) 1440
Headstock rake 24.5°
Rake (mm) 103
Front suspension Marzocchi upside-down fork with 50 mm legs,
adjustable in rebound, compression and spring
preloading
Front wheel travel (mm) 120
Swingarm Aluminium
Rear suspension Progressive linkage with Sachs monoshock adjustable
in rebound, compression and spring loading.
Rear wheel travel (mm) 130
Front brake Brembo - 320 mm double disc with 4-piston callipers
Rear brake Brembo (master cylinder and callipers) – 220 mm
mono disc with 2-piston calliper
Front tyre Pirelli Diablo – 120/70 ZR 17
Rear tyre Pirelli Diablo – 180/55 ZR 17
Rims Brembo in light alloy, 6 spokes
Front rim size 3.50 m x 17”
Rear rim size 5.50 m x 17”
Size and weight
Total length (mm) 2055
Max. width (mm) 906
Seat height (mm) 810
Min. height from ground (mm) 135
Steering angle 34° rh/lh
Dry weight (kg) 198
Performance
Top speed 250 Km/h
Capacities
Tank capacity 17 L
Reserve capacity 6 L
Instrumentation
Instrument panel Electronic/digital rev counter multifunction LCD display
Versions
Colours Black/met. grey – Red/met. grey
Warranty 2 years - unlimited mileage (European Countries)
Moto Morini SpA reserves the right to make modifications to technical
characteristics, equipment and outfits without prior notice.
En wie zei nou dat dat ding zo zwaar was?
Vind 198 kg wel meevallen.
Dat moet met dat koppel (123Nm) wel op gang te brengen zijn toch?
valt goed mee voor zo'n pachtbike...dacht eerder aan mv-agusta-geld....
ontopic: een nieuw buell modelletje 2006
en de blast komt ook terug uit... 300 cc en iets meer dan 25kw...zelf vind ik hem spuuglelijk, maarja, alles zal wel voor iemand een zekere charme hebben....
