Quickshifter type Pull te koop
R1sp knek
7 mei 2007
574
Echt
Wegens overstap op andere schakelset een quickshifter van het type Pull te koop.
Voor 150 euro mag ie weg.
Mailen naar jansen.b@gmail.com
Nee, alleen fietsen met injectie en icm powercommander of rapid bike ;)
Yep dit klopt, of hij op rapid bike past weet ik niet zeker. Op powercommander zeker weten van wel.
Word dit aangesloten op die powercomander of zo, om de ontsteking te laten onderbreken. Of gaat hij naar de computer ? :?
Ps. Sorry voor de topic vervuiling.
Voor iedereen dan:
Normally during "up shifting" you must roll off of the throttle and pull in the clutch in order to engage the next higher gear. In racing (both drag and road race), split seconds count. Rolling off the throttle, even slightly, slows your times and can be the difference between winning and losing.
The Dynojet Quick Shifter (DQS) allows full throttle, clutch less shifting. This is done by momentarily cutting the fuel and or ignition, which unloads the transmission. During this time, the rider can shift up to the next gear without rolling off the throttle or using the clutch.
The PCIIIUSB incorporates all of the Quick Shifter functionality in with the main fuel controller and is fully programmable. No cutting or splicing of your bike's wiring harness is necessary.
The amount of "kill time" is adjustable by the user via the provided software. The user can also set a minimum rpm for the system to function. This keeps the system from activating at too low of an rpm, such as low speed road riding.
Note: Certain bikes require an ignition module for Quick Shifter functionality.
This is a stand alone universal Ignition Quick Shifter module.
This unit allows any vehicle with 4 cylinders or less (motorcycle, ATV, mini sprint, etc.) to have quick shifter functionality without the need for a Power Commander. It comes with "coil cap" style connectors for easy installation on most late model motorcycles. For applications that do not have this style of coil the connectors can be removed and the unit hard wired in.
Op de site van Powercommander kan je ook zien of je een Pull of Push type nodig hebt.
Hallo
Ik heb misschien wel interesse in de quickshifter. Zou je mij een plaatje kunnen sturen van de quickshifter en de aansluiting van de kabels.
Groeten
Hette
