Tomaatje-oud
geblokkeerd account.
- 28 jan 2007
- 800
- 0
Welkom in ons mooie Suzuki GSR 600 topic!
Deeltje 1
Specs!
Displacement: 599.40 ccm (36.58 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 98.00 HP (71.5 kW)) @ 12000 RPM
Torque: 64.70 Nm (6.6 kgf-m or 47.7 ft.lbs) @ 9600 RPM
Max RPM: 16000
Compression: 12.5:1
Bore x stroke: 67.0 x 42.5 mm (2.6 x 1.7 inches)
Fuel system: Injection. 38 mm
Valves per cylinder: 4
Fuel control: DOHC
Ignition: electronic ignition (transistorized)
Starter: Electric
Lubrication system: wet sump
Cooling system: Liquid
Gearbox: 6-speed
Dry weight: 183.0 kg (403.4 pounds)
Seat height: 785 mm (30.9 inches) If adjustable, lowest setting.
Overall height: 1,075 mm (42.3 inches)
Overall length: 2,090 mm (82.3 inches)
Overall width: 795 mm (31.3 inches)
Ground clearance: 130 mm (5.1 inches)
Wheelbase: 1,440 mm (56.7 inches)
Frame type: aluminum frame
Rake (fork angle) : 21.2°
Trail: 104 mm (4.1 inches)
Front suspension: telescopic, 43 mm, adjustable
Front suspension travel: 130 mm (5.1 inches)
Rear suspension: link type, single coil, adjustable
Rear suspension travel: 134 mm (5.3 inches)
Front tyre dimensions: 120/70-17
Rear tyre dimensions: 180/55-17
Front brakes: Double disc: 4-piston calipers
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc. 1-piston caliper
Rear brakes diameter: 240 mm (9.4 inches)
Exhaust system: underseat
Kleuren 2006:
http://www.zweirad-grisse.de/images-neumotorraeder2006/suzuki-gsr600blau.jpg (Blauw), http://www.zweirad-grisse.de/images-neumotorraeder2006/suzuki-gsr600rot.jpg (Rood),http://www.zweirad-grisse.de/images-neumotorraeder2006/suzuki-gsr600grau.jpg (Grijs), http://www.zweirad-grisse.de/images-neumotorraeder2006/suzuki-gsr600schwarzmatt.jpg (Matzwart).
Kleuren 2007:
http://motoserestyle.waxtrapp.com/nmg/gx/ZyhvoznHiG.jpeg (Yoshi met ABS), http://img371.imageshack.us/img371/6505/suzukigsr600argenthk0.jpg (Grijs), http://img370.imageshack.us/img370/2136/gsr600bluemz9.jpg (Blauw), http://img371.imageshack.us/img371/4281/suzukigsr600rougerj4.jpg (Bordeaux).
Tests:
Motorfreaks
http://motoserestyle.waxtrapp.com/nmg/up/ZegbqenHmU_Test_MR_februari_GSR-600.pdf (Motorrad Magazine)
Motorfreaks Introductie
The Happy Few
-=B12=-
BertusGSR
Bidle
Zo goed???
*MODS*
- Yoshimura uitvoering
- Rempomp Nissin
- Stalen remleiding
- Ermax zijkappen
- Ermax hugger incl. kettingbeschermer
- Ermax solocover
- Ohlins voorveren
- Verschillende titanium en aluminium boutjes
- andere lampjes (knipperlichten en koplamp)
- Kofferrekje incl. topkoffer.
Booyatribes
Busaman
Chase
Danny GSR 600
De Buurman
Den Belg
Dutch_man
Dutchsuper
Fifke
GSR Rookie
Jamlem
Joshua_30
Kevke
Koidokter
Luckysan
Marc999
Mellow
Mick-in-bike-14
Mistica
Nicknick
PeerkeMikuni
Podo
Rickster
*Seven*
Snap-off
Streetpilot
Suzusmurf
The Bold
Tomaatje
*MODS*
- Streetbar stuur
- MIVV racing uitlaten
- MIVV cat. vervangpijp
- LED achterknippers
- Powercommander III USB
- Tailtidy
- Tailrisers
- Bar-end spiegeltje
- BMC luchtfilter
- Custom map voor de PCIII
- Gepolijste velgbedden/randen
- een kapotte toerenteller
op/aan-merkingen over de startpost? mail naar base bokitostaartje quicknet.nl.
wil je toegevoegd worden aan de startpost of een andere foto? laat het weten! Tevens lijkt het me leuk als we onze 'mods' onder de foto's zetten! dump ze hier als je het wat lijkt!
enne...
