xt660x topic - part 7 waar de jeugd het overneemt
YAMAHA 125 cc
Flying dutchman
19 sep 2006
3.907
139
Groningen
mijn eerste topic dus verwacht er niet teveel van
alweer 100 pagina`s verleden tijd
en totaal 600 pagina`s wat valt er nog meer te vertellen dat vind u in part nummer 7
voor meetings vragen en al het ander op gebied van de Yamaha xt660x kunt u hier een zegje doen
het verleden
xtx660 xt 660 x
part 1 xt 660 x topic - part 1
part 2 XT660X Topic - Part 2
part 3 XT660X Topic-Part 3
part 4 XT660X Topic - Part 4
part 5 XT660X Topic - Part 5
part 6 XT660X Topic - Part 6
Category: Super motard
Rating: 74.4 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 660.00 ccm (40.27 cubic inches)
Engine type: Single cylinder, four-stroke
Power: 47.33 HP (34.5 kW))
Torque: 60.00 Nm (6.1 kgf-m or 44.3 ft.lbs) @ 6100 RPM
Compression: 10.0:1
Bore x stroke: 100.0 x 84.0 mm (3.9 x 3.3 inches)
Fuel system: Injection
Fuel control: SOHC
Ignition: TCI
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: 5-speed
Transmission type,
final drive: Chain
Clutch: Wet, multiple-disc coil spring
Chassis, suspension, brakes and wheels
Frame type: Steel tube, diamond shaped
Front suspension: Telescopic forks
Front suspension travel: 200 mm (7.9 inches)
Rear suspension: Swingarm (monocross)
Rear suspension travel: 200 mm (7.9 inches)
Front tyre dimensions: 120/70-R17
Rear tyre dimensions: 160/60-R17
Front brakes: Single disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc
Rear brakes diameter: 245 mm (9.6 inches)
Physical measures and capacities
Dry weight: 177.0 kg (390.2 pounds)
Power/weight ratio: 0.2674 HP/kg
Seat height: 875 mm (34.4 inches) If adjustable, lowest setting.
Overall height: 1,170 mm (46.1 inches)
Overall length: 2,175 mm (85.6 inches)
Overall width: 860 mm (33.9 inches)
Ground clearance: 205 mm (8.1 inches)
Wheelbase: 1,490 mm (58.7 inches)
Fuel capacity: 15.00 litres (3.96 gallons)
Other specifications
Starter: Electric
mijn xtx660
powercomandor
k&n filter
acra dempers
dna stage 2 filter cover
fatbar stuur
skideplate
andere koplamp kap
en handkappen zijn onderweg
netjes zie veel onderdelen van mij ;)
dit zal het laaste xtx topic zijn waar ik veel zou zijn.
en misschien neem ik Look definitief mee naar het WR forum.:)
jammer om te hooren look
je was er van het begin aan bij
veel succes met de wr
maar hou die xtx er maar bij die doet het altyd
heb ik ook gedaan
gr
heb ik ook gedaan
gr
Het zijn nog maar gedachten. Ik ben net zo onverspelbaar als het weer.
@ YAMAHA125 cc, mooi gedaan en een mooie opzet. Ik gooi die van mij er ook nog maar een keer tegen aan.
gr, Look.
Jeetje zeg, wat een stomme titel, waar de jeugd het overneemt...
Deze 20-jarige met 30 jaar ervaring heeft gisteren weer 350 km weg gespoeld naar de Ardennen en Luxemburg. Er was een jonkie bij van 24, die nam toch mooi zijn petje af voor deze ouwe, zeker op de bochtige stukken.
Grtz, Tok
Wat in het vat zit verzuurt niet zegt men toch
ik hoop in de toekomst wat meer vrij tehebben zo dat we eens samen in de ardennen kunnen rijden momenteel nog erg druk met het werken
Geinig, ik ben bij het begin van nr. 6 gaan lezen over de XT en nu heb ik er een :) Kijken wat er gebeurt in nummero 7 !!
Vandaag mn motor opgehaald, weer nieuwe sloffen, tandwiel, ketting noem maar op! Kan er weer tegen...
Ga nu m'n vers aangeschaft H&B koffersetje erop plempen en dan volgende week op naar Schotland!!
Groeten,
Martijn
veel plezier in schotland
wij zijn met hemelvaart weekend geweest en was super bevallen
erg veel smalle weggetjes en schapen daar :]
Is inderdaad een van Meel product, en ja hij staat te koop omdat ik nog een motor in m'n bezit heb , maar ik rij er nog steeds met veel plezier op.
Ja je moet soms keuzes maken '( '(
Dat klink of ik het al eens eerder heb mee gemaakt. Sterker nog, ik zit er midden in. Maar ja, het is een luxe probleem dus we moeten niet klagen.
gr, Look.
Vraagje:
hoe is de standaard vering/demping van de XTX?
Ik ben nml ook opzoek naar een XTX en kwam er 1 tegen die vervangende spullen eronder had laten zetten, zou dit een pre zijn of voldoet standaard prima?
Mochten er nog mensen zijn die een mooie XTX te koop weten of hebben hoe ik me graag aanbevolen. Ik ben op zoek naar 1 met weinig km's :]
Hey Berry! de originele vering is gewoon prima ik heb nooit ergens last van gehad.
mijn xtx staat te koop. kijk maar op het forum te koop
