Een topic alleen voor de Honda dylan miste ik nog op het forum, dus laat ik maar zo vrij zijn?
Wilde hier graag informatie accesoires e.d. voor de dylan verzamelen, en uiteraard ook informatie uitwisselen.
Model: Honda Dylan 150
Engine and transmission
Displacement: 153.00 ccm (9.34 cubic inches)
Engine type: Single cylinder, four-stroke
Power: 15.55 HP (11.4 kW)) @ 8500 RPM
Torque: 14.20 Nm (1.4 kgf-m or 10.5 ft.lbs) @ 7000 RPM
Compression: 11.0:1
Bore x stroke: 58.0 x 57.8 mm (2.3 x 2.3 inches)
Fuel system: Carburettor
Fuel control: SOHC
Cooling system: Liquid
Gearbox: 4-speed
Transmission type,
final drive: Belt
Chassis, suspension, brakes and wheels
Front brakes: Single disc
Rear brakes: Expanding brake (drum brake)
Physical measures and capacities
Dry weight: 120.0 kg (264.6 pounds)
Power/weight ratio: 0.1296 HP/kg
Seat height: 795 mm (31.3 inches) If adjustable, lowest setting.
Ground clearance: 130 mm (5.1 inches)
Wheelbase: 1,330 mm (52.4 inches)
Fuel capacity: 9.00 litres (2.38 gallons)
Other specifications
Starter: Electric
Compression: 11.0:1
Fuel control: SOHC
Gearbox: 4-speed
Transmission type,
final drive: Belt
Starter: Electric
