Capoeirist
- 14 mrt 2002
- 10.411
- 18
De 1000's op een rij.
2001-2002
Engine and transmission
Displacement: 988.00 ccm (60.29 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 160.00 HP (116.8 kW)) @ 9500 RPM
Bore x stroke: 73.0 x 59.0 mm (2.9 x 2.3 inches)
Fuel system: Injection
Valves per cylinder: 4
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Starter: Electric
Physical measures
Dry weight: 170.0 kg (374.8 pounds)
Seat height: 830 mm (32.7 inches) If adjustable, lowest setting.
Wheelbase: 1,410 mm (55.5 inches)
Chassis and dimensions
Front suspension travel: 125 mm (4.9 inches)
Rear suspension travel: 130 mm (5.1 inches)
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 180/55-ZR17
Front brakes: Dual disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Top speed: 290.0 km/h (180.2 mph)
Power/weight ratio: 0.9412 HP/kg
Other specifications
Fuel capacity: 18.00 litres (4.76 gallons)
2003-2004
Stroke: 4
Power: 164.00 HP (119.7 kW)) @ 10800 RPM
Torque: 113.00 Nm (11.5 kgf-m or 83.3 ft.lbs) @ 8400 RPM
Compression: 12.0:1
Fuel control: DOHC
Gearbox: 6-speed
Transmission type
final drive: Chain
More details Consult a Suzuki repair manual.
Physical measures
Dry weight: 168.0 kg (370.4 pounds)
Overall length: 2,045 mm (80.5 inches)
Overall width: 715 mm (28.1 inches)
Ground clearance: 130 mm (5.1 inches)
Front tyre dimensions: 120/70-17
Rear tyre dimensions: 190/50-17
Front brakes: Double disc
Power/weight ratio: 0.9762 HP/kg
2005-2006
Displacement: 998.00 ccm (60.90 cubic inches)
Stroke: 4
Compression: 12.5:1
Bore x stroke: 73.4 x 59.0 mm (2.9 x 2.3 inches)
Fuel control: DOHC
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 166.0 kg (366.0 pounds)
Seat height: 810 mm (31.9 inches) If adjustable, lowest setting.
Overall height: 1,130 mm (44.5 inches)
Overall length: 2,030 mm (79.9 inches)
Overall width: 710 mm (28.0 inches)
Wheelbase: 1,405 mm (55.3 inches)
Frame type: Rigid twin-spar aluminum frame minimizes weight while maintaining high torsional strength
Front suspension: Inverted telescopic, coil spring, fully adjustable spring preload, compression and rebound damping
Rear suspension: Link-type, gas/oil-damped, fully adjustable spring preload, compression and rebound damping
Rear tyre dimensions: 190/50-ZR17
Color options: Blue/White, Black/Gray, Black/Yellow
2007-200x
Displacement: 999.00 ccm (60.96 cubic inches)
Stroke: 4
Compression: 12.5:1
Fuel control: DOHC
Ignition: Digital/transistorized
Lubrication system: Wet Sump
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 172.0 kg (379.2 pounds)
Overall width: 720 mm (28.3 inches)
Ground clearance: 125 mm (4.9 inches)
Wheelbase: 1,415 mm (55.7 inches)
Front suspension: Inverted telescopic, coil spring, fully adjustable spring preload, high and low speed compression and rebound damping
Rear suspension: Link-type, gas/oil-damped, fully adjustable spring preload, high and low speed compression and rebound damping
de bron : www.bikez.com
2007 Special :
Pdf bestand voor de liefhebbers: Klikker de KLIK
