Demper lekt niet en is in goede staat.
Dit is dus een RSC en niet de goedkopere CNC.
enekele kenmerken van deze demper
Fully adjustable – Damping can be adjusted in 22 positions.
Fully re-buildable with spare parts availability.
High quality bearings
Low friction design due to Ø8mm piston rod with special surface treatment.
One-piece piston rod – Perfect alignment through the slide bearings and no excessive force on the piston.
Triple function seals. Dust scraper and double oil seal, ensuring that dust cannot enter and oil cannot exit.
Nitrogen pressurized heat expansion reservoir – Gas pressure prevents against foaming.
