Consigliere_Tom
Racing Number: 66
Class: World Superbike
Date of Birth: 19 August 1985
Place of Birth: Huddersfield
Nationality: British
Hometown: Huddersfield
NINJA ZX-10R SPEC
ENGINE
Fuel System
Fuel injection: φ47 mm x 4 (Keihin) with oval sub-throttles, dual injection
Ignition Digital - Magneti Marelli
Lubrication Forced lubrication, wet sump with oil cooler - Elf
Engine Type Liquid cooled, 4-stroke In-Line Four
Displacement
998 cm³
Bore x Stroke 76.0 x 55.0 mm
Valve / Induction System DOHC, 16 valves
Transmission Clutch Wet multi-disc, manual 2.294 (39/17)
Transmission 6-speed, return
Final Drive Sealed chain
FRAME
Frame Type Twin spar, cast aluminium
Rake / Trail
25°/ 107 mm
Wheel Travel, front 120 mm
Wheel Travel, rear 140 mm
Tyre, front 120/70 x 16.5 Pirelli
Tyre, rear 190/55 x 16.5 Pirelli
Steering Angle, left / right
27° / 27°
SUSPENSION
Suspension, front Factory Showa
Suspension, rear Factory Showa
BRAKES
Brakes, front Brembo 305 mm disc
Brakes, rear Brembo 220 mm disc
DIMENSIONS
Dimension (L x W x H) 2.075 x 715 x 1.115
Ground Clearance 135 mm
Wheelbase 1,425 mm
Seat Height 813 mm
Fuel Capacity 24 litres
Curb Mass 165 Kg
PERFORMANCE
Maximum Power 220 BHP
Racing Number: 66
NINJA ZX-10R SPEC
ENGINE
Fuel System
Displacement
998 cm³
FRAME
Rake / Trail
25°/ 107 mm
27° / 27°
SUSPENSION
BRAKES
DIMENSIONS
Wheelbase 1,425 mm
Seat Height 813 mm
Curb Mass 165 Kg
PERFORMANCE
