DIY Turbo
RijNooit
3 apr 2004
6.555
Nee, het is nog geen vrijdag, maar zat wel te denken of dit nu bij off-topic hoorde of bij techniek.
DIY.Turbo-500. Mini cars. motorcycle. electric turbocharger. In order to promote air flow through the power turbine to increase engine breathing capacity of the products to improve engine compression ratio, speed up the engine combustion efficiency and reduce air pollution emissions.
Electric Motorcycle turbocharger, Specifications
20w.30w.40w.50w.60w.70w.80w.90w.
Mini cars were electric turbocharger Specifications
100w.250w.
Inlet outlet diameter of 50 mm in diameter; 35mm.36mm.40mm.42mm.44mm.50mm.
Maximum power turbine / mouth air pressure 10000Pa
Maximum power turbine / 0.5 kg of thrust out of the wind
Electric turbocharger; Accessories
1. start switch, aluminum and alloy stent.
2. fuse box and insurance tablets
3. Relay
4. relay plug
5. Control cable,
6. mounting bolts,
7. stickers trademarks,
8. mushroom air filter
Air filter;
Trumpet; small diameter 50mm, the bulk of diameter 75mm, high 90mm, 50mm interface. with stainless steel clamp 1.
Large; small diameter 75mm, the bulk of diameter 90mm, high 100mm, 50mm interface. with stainless steel clamp 1.
Electric turbocharger components. dimensions. weight;
LWH 150mm * 150mm * 130mm,
Weight; 1kg,
I just got $50 Coupons!
Ik heb veel zooi voor motorfietsen gezien op het wereld wijde web, maar dit?
Iemand hier ervaring mee? Kan toch nooit wat zijn?
Turbo turbo!
