Ik ben benieuwd.
Verkeersinfo en flitsers?
Route import in CoPilot:
How to import Routes from Google Maps? : CoPilot App Stores
If you are using CoPilot on an Android device, you can import routes from Google Maps directly to CoPilot, following the instructions below:
1. Create your route using Google My Maps (several video guides can be found on the web)
2. Export route in .kml format
3. Download and install a program to convert the file format .kml to .trp, which is compatible with CoPilot (You can find software on-line to do this such as ITN Converter or RouteConverter)
4. Connect your Android device to your computer
5. Copy the .trp files to the folder com.alk.copilot. * / EU / save (where the asterisk replaces the rest of the folder name that changes depending on the version of CoPilot installed)
6. Start CoPilot and go on
7. Select , bottom left, and then click 'Upload' to choose the itinerary
8. Follow or change the route. NOTE: Point 3 might be a little tricky if you are using the software for the first time.
Please use the forum or other resources on the network to share questions and answers on the use of software to convert files of routes. Any assistance in the use of third parties software is beyond the competence and the responsibility of CoPilot Technical Support.
**Google Maps will only accept the input of up to 10 stops**
Interessant om te weten of punten moet bezoeken (krijg je dat herberekenen).
Tracks met veel (2000 of meer) punten zal lastig te converteren worden.
