johanv
- 1 mrt 2003
- 1.130
- 12
Nieuwe amerikaanse superbike: Roehr. Geinig apperaatje, 180 pk met opvoersetje. Het lijkt alleen een beetje op een andere soort van superbike uit Europa.
Technical Specifications:
Engine:
Type 2 cylinder, liquid cooled, DOHC, Counterbalanced, 60deg, V-twin
Displacement 1130cc
Bore X Stroke 100mm X 72mm
Compression ratio 11.3 / 1
Transmission 5 speed
Clutch Wet, multi-plate, hydraulic actuation
HP/Torque 120hp / 75lb/ft
Final drive Chain
Chassis:
Type Steel/aluminum composite beam frame, 4130 steel/ 7075 aluminum
Wheelbase 56 inches (1422mm)
Rake/trail 23.5deg. / 97mm
Seat height 31.5 inches
Dry weight 425lbs. (193kg)
Front suspension Ohlins 43mm fully adjustable upside-down fork with TiN
Rear suspension Ohlins fully adjustable linkless monoshock
Front Brakes 2 x 330mm semi-floating discs, radially mounted Brembo monobloc
4 piston calipers. (Production version)
Rear brake 245mm single disc, with 2 piston Brembo caliper
Frt. Wheel/tire 3.5 x 17 forged aluminum 10 spoke Marchesini, 120/70 ZR17 tire
Rear wheel/tire 6.0 x 17 forged aluminum 10 spoke Marchesini, 190/55 ZR17 tire
Fuel tank capacity 3.8 US gallons
http://www.roehrmotorcycles.com/
Engine:
Displacement 1130cc
Final drive Chain
Chassis:
