Yamaha TRX850 topic deel 4
Trixz
20 jul 2005
6.506
304
TRX-rijders kunnen zich hier melden en lekker ouwehoeren over hun prachtige twin!
Hier staat DEEL 1 (door TR@X gestart als één van de leden uit de -raad der wijze mannen- )
- DEEL 2 én DEEL 3 voor diegene die historie willen zien ;)
:] :] :] :? Meet, Greet and Ride 2008/2009 :? :] :] :] :]
-------------------COME ON GUYS WHEN :Z by Fuzz10 and M@thijs ??--------------------
De 1e TRX MEET,GREET & RIDE (2006) heeft op 10 JUNI plaatgevonden te VORDEN(Achterhoek)
Deelnemers waren;
- Trixz
- Petrus
- TR@X
- noef
- Fuzz10
- anTRiX
- T-power
- Rattle-Head
- TRXArnold
- Wytze850
Foto's voor een impressie...
Foto=HJI3GXIH
Foto=XLRK7AEW
Foto=BN4APODZ
Foto=KWR4ZHQ6
Foto=KOHVE7IL
Engine TRX850:
Engine type = 4-Stroke DOHC 5-Valve Cylinder
Cylinder arrangement = Parallel twin
Displacement = 849 cc
Bore x stroke = 89.5 x 67.5 mm
Compression ratio = 10.5:1
Maximum power (ISO)= 61kW / 82bhp @ 7,500 rpm
Maximum torque = 84N-m / 62ft/lb 6,000 rpm
Lubrication Pressurised = Dry Sump
Transmission TRX850:
Clutch type = Coil spring Wet multiple disc
Transmission type = Constant mesh 5-speed
Gear ratios = 1st: 2.571, 2nd: 1.850, 3rd: 1.428, 4th: 1.173, 5th: 1.037
Frame and Suspension TRX850:
Frame Type/Material = Diamond / Steel Tube
Caster/Trail = 25 degrees / 99 mm
Tyre size (front-rear) = 120/ 60-ZR17 / 160/ 60-ZR17
Brake type (front and rear) = Hydraulic Dual Disc/ Single Disc
Suspension type = Telescopic / Swinging arm
Suspension Adjustment (front) = Spring Preload / Damping
Suspension Adjustment (rear) = Spring Preload/ Rebound/ Compression Damping
Performance TRX850:
Max. Speed = 224kmh/ 139mph
Standing quarter mile (400m) = 11"80secs @183kph/113mph
Power BHP = 76 @7,400rpm
Torque ft/lb = 56 @5,900rpm
Rolling acceration 60kmh-100kmh (37.5mph-62,5mph) in 3rd = 4.4 secs
Rolling acceration 80kmh-120kmh (50mph-75mph) in 3rd = 4.5 secs
Rolling acceration 80kmh-120kmh (50mph-75mph) in 5th = 7.3 secs
Rolling acceration 60km/h-140km/h (37,5mph-87,5mph) in 5th = 15.8 secs
Power to Weight = 0.43 bhp/kg
Fuel Consumption = 45-50mpg
Weights and Measures TRX850:
Length = 2,070 mm
Width = 705 mm
Height = 1,155 mm
Seat height = 795 mm
Wheelbase = 1,430 mm
Ground Clearance = 140 mm
Dry weight = 188 kg
Fully equipped = 206 kg
Engine oil capacity = 4.2
Fuel tank capacity = 18 litres
Brochures:
1995-1997.pdf
1998-verder.pdf
Onderdelenfiches:
1996 TRX: klik
1997 TRX: klik
Link naar testverslagen en diverse TRX gerelateerde informatie 'A MUST SEE'
*Thanx 2 M@thijs
Franse link naar testverslagen en diverse TRX gerelateerde informatie
*Thanx 2 m&o
Onderdelen 'online' zoeken voor de TRX ... klik HIER
Links:
TRX850 Germany site
nog een TRX Germany site
TRX picture op BIKEPICS
Zweedse TRX-fanaat
TRX worldregistration site
Franse TRX site 1
Franse TRX site 2
SpondonTRX homepage
YAMAHA TRX850 enthusiasts
TRXfiles UK
Japanse site
Konepool's TRX page
Japanner zijn TRX
Japanse site 2
Duitse test uit 1996
Tjechiesche TRX site
TRX club Denmark
Dé lijst van dé 40! MF TRX riders and one woman :j ;
- 600XTRX850
Data:
* Taartschep
* Rear wheel hugger
* Alu voortandwiel beschermer
* Alu voetsteunen en schakelpook
* Stalen remleidingen
* Goldspots
* Andere uitlaten
* Buddy-sit-cover
* On the shelf:
* Superbike-stuur en kroonplaat
* Stuurkuip t.b.v. aangepast stuur en kroonplaat.
* K&N naalden
- Alias
Foto=4FYKIQEI
- Angus
- anTRiX
Foto=EBCDNT3A
Foto=X8JUCKQA
- Aruod
- Billy the Kid
Data:
* 1998
* Lasers
* Dynojet Stage ??
- chrisbm
Data:
* 1996
* BOS Alu dempers
* Kleine knippers
* Dyno stage 3
* Losse K&N filters
* Hyperpro voorveren
* HEL stalen remleidingen zwart
- Darkbike
Data:
* 1997
* Bos uitlaten (prachtig tweecilinder geluid)
* Scott-oiler
* Seatcover
* Steunen voor een paddock achterbok
* custom made (verzonken) achterlicht en plaathouder
- Dash
Data:
* 1998
* BSM Vampire RVS dempers
* K&N luchtfilter
- Derkster *zonder Akra's nu met originele dempers
Foto=BNRDLVDM
- Dyno_jet
Foto=GX6CCNDS
- Ed@TRX
Data:
* RVS (homemade) uitlaatsysteem met alu einddempers
- Fuzz10
Foto=4WM7IQ7E
Foto=DSO6LGPG
Foto=SYZ87TUV
(c)2006 Ad Kievit ([NORML]http://www.wegraceinfo.nl[/NORML])
- Hazes
Foto=IN7NRQZG
- Headbanger
Data:
* andere spiegels
* wilbers voorvering
* K&N luchtfilter
* HEL performance remleidingen
- joebiker
Data:
* Wp Roma upside down 43mm zwarte coating
* Marvic magnesium penta wheels
* Selfmade uitlaatbochten (star twin)
* Carbon dempers leovincie
* Carbon voorspatbord
* Braking Wave remschijven
* Blauwe Remklauwen thunderace,
* Stalen Goodrich remleidingen
* VeeTwo nokkenassen
* Aangepaste standaard luchtfilter
* Geflowde cilinderkop
- Kars
Foto=LKYUYHFD
Foto=64348MFP
Foto=IACJ34NJ
*update* 01-03-2008
Data:
* 1998
* ABM kroonplaat
* ABM superbike stuur
* Stahlflex remleidingen
* Bugspoiler
* K&N filter
* Akra 2-1
- Killemall
Data:
* Leovinci Carbon einddempers
* Hardstalen remleidingen voor
* Dynojet stage II
- Laxe
- L-TRX
Foto=3QBXYDSD
- Lucasfalt *circuitfiets
- M@thijs (oude TRX van Schumi)
Foto=FNNIMO73
Foto=C3SH8J4U
Data:
* WP voorveren
* Tandwiel verhouding is anders
* R1 remklauwen
* TWP special valblokken
* BOS uitlaten
* K&N filter
* Dynojet stage....?
* Rearwheel hugger black
* Racekont
* High mounted uitlaten (special made)
* Undertray
- meissie frl.
Data:
* 1996
* BOS alu dempers.
* WP voorveren.
* Aangepaste luchtfilter en sproeiers
- Mike B
Foto=MDYOLTJG
Data:
* 1996
* Bos dempers
* Dyno-jet kit
* K&N filter
* R6 reminstallatie voorzijde
* Goodridge stalen remslangen voor
* Renntec bagage rekje
* R1 stepjes
* Andere voorveren (geen idee meer welk merk)
- m&o
Data:
* 1996
* Scorpion uitlaten
* YZF-750R UPSD front
- Noef
Data:
* TDM blok
* Verder origineel
* BOS Alu dempers
Still 2 do (this winter):
* Originele tank (zonder deuken)
* Hugger
* Undertray (die nog gespoten moet worden)
- Ook een TRiXie
Foto=JF8WCAD3
- Paling1 (zijn TRX = R.I.P.)
Foto=L4OC6ILH
- Petrus
Foto=6RJF4ZOL
Data:
* 1997
* Dé originele mooiste kleur
* K&N filter en dynojet stage 1
* YZF 750 linkhevels (dus achterkant hoger)
* Technoflex progressieve voorveren
* Voortandwiel 16 tands
* Open oval Laser uitlaten (oorspronkelijk bedoeld voor een CBR1100 blackbird)
* Stalen remleidingen voorkant
* Zelfdraai valblokken
- Punica78
Foto=H84HXHCM
Data:
* R6 remklauwen met stalen remleidingen
* FZR 600 ledachterlicht met geïntegreerde pinkers en Aliën led pinkers vooraan
* YZF750 achterbrug en upsd met bijhorende velgen, remschijven en achterrem
* MPP vooraan en achteraan
* Echt carbonnen spatbord
* Paddockdiabolo's (niet echt tuning maar allez zo ben ik toch volledig)
* Lange Pazzo Racing levers
- SpondonTRX
Foto=3RQFBEGY
Foto=7ARBIE8C
Foto=4KVG6MU8
- Rokoni
Foto=D7QBFLNR
- Tarwetijger (ex TRX van TRiX)
Data:
* Bos dempers
* Hyperpro voor en achter
* Kleine knippers
* Rode rimstriping
* 6 zuiger klauwen
* YZF koplamp met Xenon ombouw
- TeDeuM
Foto=EIO64NSR
Foto=AKGFB6SZ
Data:
* Hyperpro voorvering (wel deze voor de Franse TRXcup indertijd)
* Tandwiel van 16 ipv 17 vóór
* Alle verlichting is verwijderd
* Monozit
* Dichtgewerkte originele kuip vooraan
* Stalen remleidingen vooraan
* Selfmade valblokken
* Laptimer
* Digitaal snelheidsmetertje (sigma)
* Laser uitlaten(indien toegelaten)
- tiggermac
Foto=XJC6NX7I
- tracTRiX
Data:
* 1997
* K&N
* Hugger
* Uitgeboorde originele dempers
- Trixz Main topic leader part 2/3/4
Data:
* 1999
* Bridgestone BT014's with a 120/70 in front
* Braided brake lines front and back
* Dynojet Stage 3 [Tovami by Ruud Fredriks]
* K&N separate airfilters
* Wheelrimstriping
* Bikedesign crashpads black
* Small (Smoke) indicators
* Rear seat cover black
* StainlessSteel exhaust mounts with YAMAHA logo
* Rearwheel hugger NWS Black
* Pazzo Black Short brake and clutch levers
* Braking Wave front and back
* GP-style gear shift 1 up and 4 down
* Full WP suspension, front springs and rear the Fusion with PA!
* RairoTec rearset
* Pro Bolt Black Preload adjusters front
* Pro Bolt Black paddock stand bobbins
* Coerce Drive Sprocket Guard
* Coerce Front Fork Stabilizer
* Xenon headlight conversion
* Custom made exhaustsystem with custom made Akrapovic cans
* LED taillight
Wanted:
* Wheels (aluminium)
* YZF 750 swingarm ?
* YZF 750 UPSD ?
Movies:
Fly by on the Nordschleife 'The Ring' Germany
Tankcam test 1
Dyno with Stage3
Tankcam test 2
Tankcam part 3
Tankcam part 4
- Tr-X850
Data:
* 1996
* Dynojet Stage 3
* K&N filters
* 2 in 1 Akra
* Voorzijde progressieve veren van WP
* Stalen (HEL) remleidingen
* Undertray
- T-Power
Foto=ETQFZII7
Foto=HC4DICOW
Data:
* 1999
* Spiegler remleidingen
* "Body Style" onderkuipje
* Duozit afdekkap (met het zelfde profiel als de tank)
* BOS dempers met BOS uitlaatsteunen.
* K&N Luchtfilter ipv origineel filter (voor de rest motorisch origineel)
- Vieze
Data:
* Termignoni's!
- Wytze850
Foto=XEIELW3V
Foto=G4LTWACS
Foto=FJPK7ZUS
Foto=W3HR4XQQ
3x (c)2006 Ad Kievit ([NORML]http://www.wegraceinfo.nl[/NORML])
*O* HAVE FUN ON THIS TOPIC *O*
Wie plaatst (na mij) dé eerste reactie....... :9
We have a winner *O* and thanx *D I will :Y
Verdomme, net te laat! Och ja een vijfde plaats is ook niet slecht.
Gisteren zijn trouwens de clipons voor de upsd-conversie binnen gekomen en hopelijk van de week het wiel met remschijven :Y
FF melden hiero.
bijdeweg,
Wanneer gaan we toeren? Nou?
Van wat ik uit deel 3 van lang geleden *kuch* heb begrepen gaan er plannen gemaakt worden over ongeveer 2 à 3 wkn vanaf nu :P
Dus dat zal na de zomervakantie zijn denk ik, net als de vorige in 2006 :]
Klinkt goed :Y dan heb je binnenkort weer wat te doen *naast de poepluiers :+
Had jij in 2006 op 10 juni je zomervakantie er al opzitten? :P
Enne gefeliciteerd allemaal met het nieuwe topic! *O*
Ja, ben er ook weer bij in deel 4 (zoals jullie van mij gewend zijn iets later dan sommige anderen maar wellicht kan ik dat bij de volgende meet and greet rechtzetten...).
Ben zelf van 7 tm 29 juli met vakantie dus als de M&G in die periode valt ben ik er even niet bij. Valt ie buiten mijn vakantie dan moet er wel iets heel geks gebeuren wil ik er niet bij zijn.
Hoi allemaal,
Ik heb behoefte aan een eerlijk antwoord van degene die ervaring hebben met de volgende vergelijking:
Waarom de TRX verkiezen boven de SV650?
Wil na mijn Soez GS500 eindelijk weer een andere motor kopen en het moet natuurlijk een 2 cilinder zijn die in mijn budget past. Deze 2 komen iig in aanmerking, maar een proefrit maken zit er voorlopig niet in. Kunnen jullie mij overtuigen?
BTW: heeft een van jullie ervaring met het ombouwen van de topkuip van de TRX naar een streetfighterkuip, vooral met de bevestiging van de meters ed.?
Hoop hier wat nuttige info te krijgen, maar ik heb een tijdje dit topic gevolgd (ook deel 1,2 en 3) en verwacht eigenlijk ook niet anders.
David
Hoi allemaal,
David
Hoi allemaal,
David
Hoi allemaal,
David
Daarvoor kan je het beste bij TeDeum terecht, die heeft er zo al een paar verbouwd.
Hoi allemaal,
David
Voordat er iemand over begint: dit ben ik niet met een ghost account :+
en ik hou mijn ervaring maar voor me :X
Is er niemand met een TRX in de buurt van Hoorn. een goeie that is? ;)
Maar ach, ik denk dat het toch de SV gaat worden als ik ooit geld heb.
Dan heb je zeker een rotte TRX getroffen ; je kunt veel van de TRX vs de SV zeggen. Een SV loopt harder, stuurt sneller, remt beter en is lichter , maar als het op (motor)karakter aankomt dan is het geen partij... Dat wint de TRX echt makkelijk... Een SV loopt toch alweer een stuk smeuiger (en veel hoogtoeriger dan een TRX)....
@Datiggerr...
TRXArnold heeft net in deel 3 nog het volgende antwoord aan Dash gegeven lees maar;
@Dash,
Ik geloof dat ik me een beetje in je gedachten kan verplaatsen, zoals je weet had ik tot voor kort een Hawk, heb ik nu een SV650 (S Yoshimura weliswaar) en heb ik ook een TRX.
De Hawk en SV zijn beiden een aardig stukje lichter dan de TRX 207 volgetankt klopt wel, en dat scheelt ruim 20 kilo met Hawk of SV. De SV voelt naar mijn mening nog lichter aan dan de Hawk en de TRX is iets meer werken. De TRX heeft een sportievere zit dan de standaard Hawk, iets meer afstand naar het stuur maar iets minder ruimte voor de benen.
Een SV zit tussen de 70 en 75pk, de TRX standaard 82 maar het verschil in koppel is veel groter. Een SV voelt bij middentoeren minder sterk aan dan de Hawk maar gaat de toeren in bijna als een 4-cilinder. De TRX is in het middengebied een stuk sterker dan de Hawk maar draait minder toeren. Gemiddeld schakel ik met de TRX een 3000 toeren eerder over dan op de SV. Een kale SV is qua zit nog het meest te vergelijken met de Hawk, de (nieuwe) SV650S zit nog een stukje sportiever dan de TRX.
Om niet teveel off-topic te gaan kun je me anders ook wel mailen als je wat ervaringsinfo wilt.
grt
Arnold
Ps. één post is genoeg hoor ;) per keer...
Mijn mening SV versus TRX, rijden en dan beslissen, maar het is ook saai versus KARAKTER O-)
Heeee, deeltje 4 alweer *O*
Euhh, vraagje.
Nu heb ik afgelopen week een nieuwe ketting + tandwielen aangeschaft.
Maar nu past het TDM-achtertandwiel niet.. -O-
Gelukkig zo om kunnen ruilen voor TRX-tandwiel, maar wat heb ik fout gedaan?
Mooi deel 4 alweer.
Als aankomende Zaterdag op Assen de trix nog rijdbaar is dan.....bouw ik hem weer terug naar straat modus.
Zal dan eens bezig gaan met een rout samen met Fuzz uiteraard :)
Helaas, same here. |(
Ik ben heel graag weer van de partij, zeker na de ervaring van vorig jaar :} , maar dan pas vanaf augustus.
