Dat ziet er trouwens heel goed uit :0
Heb je meer foto's van de Domi en wat heb je er allemaal aan gedaan?
Honda Dominator 1992
Custom made subframe with build in rear LED light and indicators
Custom made wheels with satin black rims with original hubs
Frame and fork legs powder coated in black wrinkle coating
Honda CG125 tank made to fit
adjustable mx variable link
JE big bore HC pistonkit 102mm 11.25.1
HotCams stage 1 camshaft
Keihin FCR MX 43MM + acceleration pump
Lightend flywheel for better acceleration and torque
Ports worked for better flow
Hyperpro streetbox kit with progressive front springs and complete shock absorber
Bigger 320mm brake disc and adapter
GPR header pipes
Tyga Performance Maggot double silencers
Custom pipe work
Shido lithium accu
Motogadget M-Blaze led turn signal pin
Forkprotectors
fast throttle handle
RENTHAL fatbar
Handlebar risers
Aluminium front fender
Tachometer 60mm
front light 5inch LED
Rear tire Trail Master 705 130/80 H 17
Front tire Pirelli MT60RS 110/80 R18
Custom steel enforced brakelines
short clutch and brake levers
Motogadget M-Switch 3 button
Aluminum cnc control button
Stainless steel complete bolt set
Engine painted in satin black
Plate holder Highway Hawk
Handlebar risers
