Vond trouwens een heel verhaal op een amerikaanse site misschien wel grappig
GS 1100 GK 1982
Overall Length: 2 490 mm (98.0 in)
Overall Width: 930 mm (36.6 in)
Overall Height: 1 545 mm (60.8 in)
Seat Height: 800 mm (31.5 in)
Wheelbase: 1 495 mm (58.9 in)
Dry Weight: 290 kg (639 lbs)
Engine type: Air-cooled 1 074 cc inline-4, DOHC, 8 valves. 98 hp/ 8.700 rpm, 8,69 kg-m/ 6.500 rpm. Shaft drive.
Click on the image for larger format. Here's even larger picture.
1982—1984 Suzuki GS1100GK Specifications (USA)
Overall length:
2 490 mm (98.0 in)
Overall width:
930 mm (36.6 in)
Overall height:
1 545 mm (60.8 in)
Wheelbase:
1 495 mm (58.9 in)
Ground clearance:
145 mm ( 5.7 in)
Dry mass (weight):
290 kg (639 lbs)
Engine type:
Air-cooled inline-4, DOHC, 8 valves
Bore:
72.0 mm (2.835 in)
Stroke:
66.0 mm (2.598 in)
Piston displacement:
1074 cm3 (65.5 cu. in)
Compression ratio:
8,8 :1
Carburetor:
MIKUNI BS34SS x 4
Air cleaner type:
Polyurethane foam element
Starter system:
Electric
Lubrication system:
Wet sump
Clutch type:
Wet multi-plate
Transmission type:
5-speed constant mesh
Gearshift pattern:
1-down, 4-up
Primary reduction:
1.775 (87/49)
Final reduction:
3.090 (34/11)
Gear ratios:
Low
2.500 (35/14)
2nd
1.722 (31/18)
3rd
1.380 (29/21 )
4th
1.125 (27/24)
5th
0.961 (25/26)
Final drive:
Shaft drive
Front suspension:
Telescopic, gas/coil spring, oil damped
Rear suspension:
Swinging arm, gas/coil spring, oil damper 4-way adjustable
Steering angle (left to right):
40 degrees
Caster:
61° 95'
Trail:
118 mm (4.65 in)
Turning radius:
2,6 m (8.5 ft)
Front brake:
Twin disc
Rear brake:
Single disc
Front tire size:
110/90-19 62H, tubeless
Rear tire size:
130/90-16 67H, tubeless
Ignition type:
Transistorized
Generator type:
Three-phase A.C. generator
Fuel tank capacity:
22 l (5.8 US gal) incl. reserve
Reserve:
4,2 l (4.4 US qt.)
Engine oil capacity:
3,0 l (3.2 US qt.)
Front fork oil capacity:
363 ml (12.0 US oz)
Secondary bevel gear oil capacity:
340—400 ml (11.5-13.5 US oz)
Final bevel gear oil capacity:
280—330 ml (9.5-11.2 US oz)
1982—1984 Suzuki GS1100GK service info:
Cylinder head valve lash:
0,03—0,08 mm (0.0012—0.0031in)
Ignition timing: 17° B.T.D.C. below 1 500 r/min and 37° B.T.D.C. above 2 350 r/min
Spark plug type:
NGK B8ES or Nippon Denso W24ES-U
Battery:
YB14L-A2 12V 14 Ah (50.4 kCI/ 10 hours)
Fuses:
10/10/10/10/15 A
Headlight:
12V 60/55W
Tail/Brakelight:
12V B/23W (3132 cp)
Turn signal light:
12V 23W (32 cp)
License plate light:
12V 8W (3 cp)
Speedometer light:
12V 3,4W
Tachometer/Fuel meter light:
12V 3,4W
Neutral indicator light:
12V 3,4W
High beam indicator light:
12V 3,4W
Turn signal indicator light:
12V 3,4W
Oil pressure indicator light:
12V 3,4W
Side stand check light:
12V 3,4W
Gear position indicator light:
12V 1,2W
